My partner Stephen and I have just returned from two days in Bendigo, a lovely old town a few hours north of here, a historic gold town from the 1850s gold rushes. We had some stuff to do there, decided to make a mini-holiday of it.
There is an excellent recycling centre in Bendigo, I went there for a look and chasing a gas heater fan for a neighbour. What I wasn't looking for was another washing machine. But I found a Turner washer, I'd guess from the late 50s or early 60s, a round body machine which is manually operated but heats its water, washes and spins in one tub. It is quite small.
We were in Stephen's car, a Holden Barina which is a tiny hatchback about the size of a Hyundai Getz. It was already half full with our luggage, plus we had to buy a weeks groceries on the way home, so space was at a premium...
After some tense negotiating I got "permission" to bring it home on the back seat of the car, if it would fit. It just fitted.
It is late, my back is very sore so photos will have to wait. It appears complete. it is simple - no gearbox, there are two belts and some pulleys underneath. The drum and agitator are fixed together like an agi-tub. There is a knob on top of the agitator. Turn the knob one way, the motor drives a two-step reduction via both belts and an idler pulley, to a crank which drives the agitator and tub back and forth. stop the machine, turn the knob the other way, it bypasses the idler and crank, drives the agitator and tub fast one way - spin. Pump is engaged manually with a lever, centre position is off, one way is marked "in" and one way is "out". This is not working properly, it stays engaged. I think it is to pump water in or out, pump in = suds save. (?) It has a main switch, turn one way for "on",centre off, other way for "heat". One of the belts is missing too.It was partly disassembled when I found it, but it only took a few minutes to put it together, it is quite simple. It will need a belt, a couple of circlips, some grease, a hose or two, some attention to the pump linkages, a good clean, a power cord, and I will have a fun old washer.
chris.
chris.
