I also have the GE version. You have control over the water levels and there is no auto temp control, hot is as hot as your water heater gets. The super water level fills 2 inches from the top, you can hold the reset on the water level switch and get a fill right to the top. My washer is the 3.9 cu ft. tub, so I seldom find the need to use the reset. You can adjust the water level switch just like the Speed Queen can be adjusted, I just don't see the need to do so. I have had my GE for 2 1/2 years, no problems or issues at all. It cleans very well, has the same timer control as the Hotpoint and completes a super load in 40-45 mins. If you use the Power Rinse option you get a full fill rinse. I have been completely satisfied and I'm pretty sure that the only difference between the GE and Hotpoint is the plastic tub. From what I've heard the plastic tub is the same material used in dishwasher tubs and is durable.
