nmaineman36
- Joined
- Sep 25, 2004
- Messages
- 933
Answers..I hope...
Here is the breakdown on the cycles for the washer. Each one presets the temps and spin speeds..of course you can change each one to tailor the individual cycle as you see fit.
SuperWash 1 hour 40 mins w/prewash, warm/cold water, heavy soil level,MaxExtract Spin. Extra rinse adds 13 mins to each cycle. ex Spin adds 3 mins to each as well.
Normal cycle 54 mins warm/cold max extract,med soil.
Whites cycle 1 hr 5 mins hot/cold ex rinse,maxextract med soil.
Wrinkle Control 45 mins warm/cold, med spin med soil.
Colors 56 mins cold/cold med spin med soil.
Delicates 45 mins warm/cold gentle spin,med soil.
Hand wash 47 mins cold/cold low spin,low soil.
QuickWash 29 mins warm cold med spin,low soil.
Spin Speeds Max Extract = 1100 rpms
Medium = 800 rpms
Gentle = 600 rpms
Low = 400 rpms
Drain only = 0 rpms
Suspension 2 springs 4 struts
Auto Temp Control warm wash = 105 degrees, warm rinse = 80 degrees, cold wash 65 degrees
water temp is maintained by internal heater hot is 155 degrees.
Rinse /spin option is a cold rinse med spin 15 mins
spin only 9 mins med spin.
DRYER
Sensor Regular 46 mins Normal dry Reg Temp
Wrinkle Control Sensor 50 mins less dry med temp
Time dry 40 mins regular temp
Freshen Up 15 mins reg temp
Delicates 35 mins low heat
Air fluff 20 mins
Wrinkle Release 18 mins reg temp
Quick dry 30 mins regular
Temps are Regular Temp = 154 degrees
Medium Temp = 146 degrees
Low Temp = 138 degrees
ExLow Temp = 125 degrees
7.3 cu ft drum 200 cfm airflow air enters drum upper right and is pulled thru drum to bottom of door opening.
Quick fast and effective airflow. Gas burner rated at 22,000 btus. Clean burning no yellowing of fabrics. And yes folks I know some believe that Gas dryers do not yellow fabrics but if you compare a white load dried in an electric dryer to a gas one you can see the difference. This dryer seems to not yellow the clothes like the last one we had.
Medium = 800 rpms
Gentle = 600 rpms
Low = 400 rpms
Drain only = 0 rpms
DRYER
Air fluff 20 mins
