Re: Profile Page:
Hi! filterflo702 and a "better late, than never welcome" to you. If you go to the opening page of the "Discuss-O-Mat" and look towards the bottom of the page, you will see where it says about the Profiles. Click on that to open the Profile Page and it should then mention about your info and what you would like to do, as far as completing your info on your Profile.
"BTW" not to be corrupting you purposely, but the WP/Kenmore and other's that have/had the Water Drain before going into the Spin, is called a "Neutral Drain." I have done what you mentioned about as well, with some of my "B-D" Models, of holding the Safety Switch, with the Lid opened to watch the Washer try to "Spin-Drain" and watch it stop Spinning, to complete the Draining, before going back into the Spin. If I remember correctly, on the "Neutral-Drain" Washers that had an Infinate Water Level Control, I believe that I also held the Knob over to the "Reset" and I think that the Washer would still "Spin-Drain" then, instead of Stopping/Starting the Spin.
Peace and Holiday Cheer, Steve
SactoTeddyBear...
