sudsmaster
The advantage of a graphite moderated reactor begins and ends with that it can use natural uranium with a U-235 content of 0.7%. A boiling water reactor, which uses purified water as the moderator, requires a higher concentration of u-235: 3%. This means extensive plants must be constructed to enrich the uranium to run in a BWR or other water moderated reactor. The Canadians got around this by using heavy water - deuterium - as the moderator, which can use natural uranium as well, without the hazards intrinsic in a graphite moderated design.
I don't think anyone is currently proposing a 100% nuclear powered electric infrastructure. Nor is anyone proposing a 100% breeder reactor nuclear infrastructure. A mix of power sources - which would include fossil as well as renewable, is most likely. Here in the US there's great potential for solar power - we're already making large amount in some of our desert areas using thermo electric maans - the sun's energy is concentrated and used to heat water which in turn drives steam turbines. More of this is on its way. Then there's wind power, of which the US is the world leader at present. Photovoltaic is a great option of individual businesses and residences, but the cost of the silicon panels is still too high. One advantage of solar is that its energy production peaks at about the same time demand peaks - during the hottest parts of the day in climates where AC is needed.
