Sorry, Launderess, but I have to take issue with several points made in post 208882:
*The Fisher/Paykel washer was not low-rated. Its overall score was still well into the Very Good area. In fact, it scored only 9 points lower than one of the Oasis/Cabrio models, which scored a 73---also in the Very Good area.
*Only three of many frontloading models tested scored low (Fair) in gentleness to fabrics. Two of those were the new Kenmore HE5 and its Duet eqivalent, which have cycle times of 105 minutes. CR opines the long cycle probably has something to do with why those machines are rougher on fabrics. Most other frontloaders scored Very Good or Excellent in gentleness.
*The poor cleaning scores received by a growing number of toploaders is attributed to dumbed-down water temperatures, not the amount of water used. Decreased water levels do, however, negatively affect the capacity scores.
I don't have a 'wet-nap' frontloader. As you can see from CR's water efficiency scores, my original-issue Frigidaire FL is a relative water hog in comparison to many other FLers. It also scores lower in cleaning ability than most of the very-low water usage machines. CR determines cleaning scores by washing both a standard 8-lb. load and a load at the washer's maximum capacity. So even when they're fully loaded, the wet-nap machines seem to be cleaning well. I'd be more curious to find out how well they're rinsing, actually.
Having said all that, I agree completely with your point that lowered water temps and the resulting poor cleaning scores will only cause users to wash some items twice. I'll add one more to that: It's stupid to decrease maximum water levels on TL'ers, thus restricting their capacity. Doesn't it use more water and energy to split a large load into two rather than letting the machine use 6 more gallons of water per cycle which would allow a user to take advantage of its maximum capacity?
