dylanmitchell
Upgraded to the Speed Queen AWNE92SP Washer and ADEE9RG Gas Dryer. Wanted a top loader with full water fill options, no lid lock, brake, metal parts, reliability, and durability. New 2018 Speed Queen models will have the one horsepower motor (to push tub back and forth), neutral drain, no brake, lid lock, and belt. They may be a better more efficient machine or they may be worse but I wanted to stick with old school until the new school has been out for a while.
Like being able to do full water/ full tub fill loads especially for bulky items like bedding and dryer lint filter is easy to access. Set up is working well so far but have only had it for a few days.
Before first laundry load I cleaned up the washer tub and dryer drum to remove oil and dirt from manufacturing, swapped in a short run of semi-rigid metallic duct on dryer, and fitted washer hose filter screens to the Eastman PVC wrapped stainless steel hoses I'm using. Delivery/ Installer guys used Aluminum Foil Duct and left out hose filter screens. With the Eastman hoses I was able to remove the washer and insert the washer/ filter screen that came with the machine. I prefer the semi-rigid metal ducts vs the foil and wanted to upgrade hoses vs what Speed Queen includes.
