New to me - Hotpoint drop in oven
capefolly
Aug 15, 2022
4
Chicago
Newbie here I just purchased this original 1973 home in cape cod and love the original drop in oven. Everything except the oven works. Any thoughts? I can’t find a replacement thermostat for it. Any help would be greatly appreciated. It wouldn’t be the same without it.
Long shot, but if the clock and timer on the stove no longer work, try moving the 'hours to cook' dial to MAN.  The timer may 'think' it's engaged and waiting to start the oven at a specific time.  I can't tell you how many times I've had this happen with vintage stoves!
Nice Range.
Because Hotpoint and GE used the selector switch with the Timed Bake setting, the clock does not have a manual setting. What I think I notice is that the start and stop time dials are not in the same position. Try synchronizing them both to the same time. When they are set to the time showing on the clock, they should both pop out since they need to be pushed in to set them. The clock is probably not working so with the two dials set to different times, it is waiting for the clock to move into position to trigger the start time, which is not going to happen. Give this a try and report back. A mouse might have attacked a wire which could stop the clock, but it is an old clock so it might have retired itself. I believe that you might be able to make the oven work even if the clock is not working.
Good catch Tom! I noticed that the start and stop times were set different but I didn’t realize that this stove didn’t have a manual setting.
I should have realized this though since when we moved into our home 28 years ago the original stove was a 1980 Hotpoint Slide In stove that had a similar control panel. But since we replaced it soon after moving in I only used the timed bake setting once and forgot exactly how it worked.
I bet your good instructions will help get this oven back into action.
Eddie
1973 hot point self cleaning oven by GE
This is a very good stove and may be a fairly easy fix but you may have to find a repair person with some gray hair, if it simply doesn’t heat at all I would check for a bad oven sensor first, there is not a thermostat per se in this oven system.
The oven control system is made up of about six different parts and you need to find somebody who can figure out what’s causing the problem.
He’s ovens were generally not very troublesome and they baked beautifully but something does happen eventually.
John L
Would the start and stop time matter if it was set to bake vs time bake?
Unfortunately the owner put red plastic drops to see the indicators better.
If the clock doesn't work, the rotor with the pinion that turns the gears could be frozen.  If you're handy and you can access the clock, you can find a replacement rotor on eBay, etc.  I don't think the smaller types of rotors GE/Telecrhon switched to in the late '60s (the "S1" type) can be revived like the older, larger ones ("H3" type).
From what I've read here, the "Sensi-Temp" burner controls are no longer made.  You'll have to keep and eye out on eBay for one of those, too.
Replies 11 and 12
Hi Ralph, on the stove the clock has nothing to do with normal oven operation.
The stove also does not have a sense a temp burner to worry about.
Hi Bob Frigidaires had such a complicated oven control system that I’ve sometimes converted those to regular systems I’ve never found that necessary on a GE hot point range this is not a hard to fix.
To the owner of this wonderful range test the sensor for resistance it should’ve about 17 1/2 ohms, if it is open I’ll find the part number of the sensor for you.
I fixed a wonderful GE range of the same age for Keven of cavalcade of food last weekend here are some pictures of it it had a different problem the oven was heating but not heating properly it had a bad oven heating relay but it’s the same system this Hotpoint uses.
Photo #4
That's a far more complex design than I would have anticipated. Damn good looking range though, wow. Great job fixing Kevins range, John.
Early P7 GE self cleaning ranges
Thanks Dan, GE ranges are always fun to work on because the wiring it’s not all bundled and it’s easy to trace.
I should’ve mentioned the picture is Anthony and his mother with Keven of course in the background.
Anthony is a very good guy to work with very technically able.
Kevens stove had an unusual problem it would heat up to 350 and never come back on and it turned out to be a bad hot wire heat relay I’ve only seen that problem once before and it was on a similar age range about 35 years ago.
I brought all the possible parts along with me so it was an easy fix.
John L
John saved the day!
John - it was so good to see you, Anthony and his mom last week! I'm grateful for your repair on the GE. It's a beautiful range but I just couldn't understand why the oven wouldn't hold temperature. Luckily I knew a repair tech with decades of experience to troubleshoot the problem! Thanks again!!
John, thanks for the info about the clock.  That eliminates one repair job, unless Scott gets tired of looking at a clock that only tells the right time twice a day.
My sister
had that kitchen with a turquois confetti counter top, and a white 40 inch GE P7 range. It served it's purpose since 1956, and is gone as of spring, replaced by modern updates. Granite, high quality solid cherry, and black stainless or graphite LG screen fridge, convection/induction range and dishwasher. The old stove still worked, but needed a part for the oven. The gold 70's Armstrong Solarian flooring was even still in fine shape. The flow is much nicer now blending with the hardwood flooring in the dining area.
For some, When it's time, it's time.
