1994 29inch whirlpool gas dryer
This afternoon I did a service call on this dryer it’s the only dryer in a small four unit apartment building, needless to say it’s had a lot of use and it has about a 15 foot fence that goes up through the roof.
Previously this dryer has needed new valve coils in about three years ago I put a belt and two rollers on it.
The complaint was it was making strange noises, when I checked it out the motor bearings were indeed failing so I set about putting a new motor in it. I was not able to get the blower wheel off it cracked so I had to take the dryer completely apart and remove the rear exhaust duct that the lint filter slides into.
There was only a small handful of lint at the bottom of the duct in the trap area it was not impeding airflow at all I did clean it out put the new motor in and put a new blower in.
Dryer ran like new will probably work at least another 10 years even with 15+ loads a week of use.
Even though lint does accumulate at the bottom of this duct it does not build up to the point where it will Impede performance, if it builds up too much it just get sucked into the blower and the blower wheel as usual was completely clean even after 28 years of use.
John
John
