New Toaster?
good-shepherd
Nov 21, 2017
788
New Jersey
Out two slice Toastmaster is acting up, only the outer elements heat.
Chrome and white model, it has been trouble free since new, probably mid 90's vintage a least.
Any suggesting for a replacement new or vintage?
-Thanks
Any vintage Toastmaster would be good, even if it's as much as 80 years old.  The late '40s ones are pretty much indestructible.  We had one growing up.  I have an updated version on standby in the basement.  Here's the same type going for $96.  I paid less than $10 for mine several years ago, and it's barely used.
Here's the late '40s style on the same chassis:
I like this style a lot too, and they are solid:
It's probably just a break in the nichrome heating element.  Toasters aren't that hard to fix.  What I recall about taking apart the type in picture 2 of my post above is that getting them back together requires careful alignment of the vertical segments that keep the bread from contacting the elements.
Since the nichrome in a toaster heats up to a red glow, I'm not sure the borax and brass jewelry wire fix is applicable in this case (see link -- scroll down 40 replies or so).  If there's a break near the electrical connection, there might be enough excess wire to simply make a new connection.
http://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?44066
