gyrafoam
JeffG-----
You can make it possible to have a warm rinse by using some "splitters" and you'll need a couple of short hoses.
One of the splitters will need to be the type with the tiny individual valve controls on each side.
Install the splitter with the valve controls where it is most convenient for you to open and close them.
You attach a splitter to the hot water valve, then attach the hot water inlet hose to one side of the splitter and a short hose to the other side.
Then attach the other short hose to the cold water valve.
Take the other splitter and attach both short hoses to it.
Then take the original long water inlet hose and attach it to the single point on the splitter. Get the picture?
Then you can use the tiny valve on the hot water side to "mix" in hot whenever you like and make warm rinses possible.
Personally I like the splitter with the tiny individual controls down where the short hot and cold hoses meet--- so I can turn the cold off and have hot rinses when I want. I "hot rinse" a lot. Especially effective in the Unimatic and SQ.
