58limited
I was given this radio today. When I turn it on, it plays well for about 10 minutes and then the sound starts to fade. Is this a capacitor issue? I haven't opened the radio nor have I tested the tubes yet. The magic eye tuning indicator lights up but doesn't do anything as I tune - not sure if it is the tube or the caps, or something else. The right side tweeter speaker doesn't work. The FM push button won't stay down unless you push the button next to it first. And the tuning indicator is off - channel 99.9FM was playing when the indicator was at 95.0FM.
Is this radio worth paying for a shop to repair it or would it be better as a shelf decoration? Is it considered a good radio? Worth much? The limited research I've done today (Google and Yahoo for about 15 minutes) basically says that repairing German radios is not for the novice. I'm less than a novice with electronics so I'll take it to a shop for service, I'm just trying to determine the possible problems so I can ask for a rough estimate before hauling it in.
This same gentleman also gave me a Chickering upright piano from the 1880s. Me and a friend went to move it at lunch, going back to attempt to move it later with several more helpers - it is HEAVY!
