The guy in that video is a blethering arse!
The reason for switches on UK sockets is twofold:
1: to disconnect the live side, rendering the flex and appliance safe. The plug can only be inserted one way, so the live conductor in the appliance and plug is always connected to the live side of the socket, provided the socket and plug have been correctly wired.
2: to provide a means of switching the appliance off should the onboard switch not be present or fail - and more recently, those appliances which are always 'on' such as tellies. I certainly don't trust leaving it plugged in, always on, even when it is supposedly off.
You can still buy unswitched 13amp sockets. These might be used where a dishwasher or front-loading washing machine are installed under a countertop. Typically, a double-pole isolator switch is installed on the wall above the countertop, possibly labelled with the type of appliance, e.g. 'Dishwasher', and with an integral neon lamp.
Oh, and as for sparks from plugs and sockets being safe... This refers to the 2-way or 3-way cube block adapters, but it is still relevant:
"An inspector said the fire began next to her bed, where the adaptor was plugged in and had fallen slightly out of its socket, creating a spark."
Derry Girls Siobhan McSweeney has been left haunted by a raging house fire that burnt her home down, and is still living out of a suitcase four months later
www.mirror.co.uk
