whirlcool
Last night we were doing some laundry. When we were running the last load, we noticed water on the floor in front of the WP washer. It looked like it was coming out from under the front of the machine. I figured the washer was leaking.
Checked the fill valves on the wall. No drips, checked the floor behind the machine, wet floor. The floor looked like it had been wet for awhile. Maybe 4 or 5 gallons on the floor.
Finally a closer examination of the steel braided no burst hoses connecting the washer to the valves on the wall reveled the answer! The connector that screws on to the water valve sprung a leak where the hose going to the washer connects to it! The water was leaking down the hose and dropping off at the loop at the bottom before it goes to the water inlet valve on the washer. So we finished up the load that was in the washer, shut the valves down and I'm going to replace those non-burst hoses with conventional ones. But I should say that the hoses were fourteen years old. I guess nothing lasts forever!
