European regs vs Us regs
Most European machines I have used seem to have a tested cottons cycle they use to meet the water consumption requirements and then, if you want, you can just pick a different cycle or select options like Water Plus on Miele.
They inform you of your options but you’re not usually stuck with water miser cycles if you don’t want them.
Usually selecting a higher speed cycle / time saver option will decrease the efficiency by increasing water levels and reducing cycle time. The same applies on a lot of dishwashers.
