rinso
There has been a lot of discussion about machines with a neutral drain operation, mostly Whirlpool and Kenmore. My question is, when a machine does not have a neutral drain funciton, what provides the slippage so the motor doesn't overload while turning a tub full of water? I know that the helical drive Maytags were designed to use a special drive belt that was loosely coupled while being pulled in the spin direction so that it drove the pump at a near normal speed, but the tub didn't catch up until it was empty. If a regular dry clutch is used, how does it keep from burning its linning up? My Norge didn't release its tub brake until the water level got down to a pre-determined point. During that time, the tub was held stationary by the brake, but it's drive shaft turned. Can anyone enlighten me? Thanks!
