Thanks everyone! This machine is really growing on me, especially because of the color (so much "louder" than the gold color of the 1-18 next to it, which is more of a sunny yellow than anything) and the fact that the stream is considerably less splashy than the Dispensall. I think that even after I change out the pump on that machine, I'm keeping "Goldie" in to play for a while. Tom, very interesting information as well...I never knew that the solid-tubs paused during spin. Although I didn't really pay much attention to Greg's 1960 solid-tub at the Convention so I never saw it pause.
Vintagesearch, the problem with GEs rusting (and mildewing) under the lid, top, and whatever else is the fact that with the lid left down, nothing can dry out. With that design, the top and outer tub are completely sealed from the cabinet. On other machines (such as a DD Whirlpool or later plastic GE), both the cabinet and tub assembly aren't sealed from the top, so most of them don't have this type of problem. The best thing to do with any machine, though, is to just leave the lid up for a day or two so everything can dry out properly. That's what I do with mine.
Baja, beautiful coppertone 70's model you have there. The "Extra Large Capacity" designation means an 18-pound tub, while "Large Capacity" is the 14 lb. (I believe) like mine. I'll go down there and get the model number and the serial number to post. If anyone has an 80's GE date code book and can determine the date, please post it! I tried it with my 78-80 book and it said June of '78, which is way off! I guess they re-used the first two letters of the serial number (which on mine is LD) over the years.
Shane, I got the email you sent me about the varieties of Fresh Start and I'll be replying after I post this! As for Bold Plus, the last time I was at our local store (before the October wash-in) to stock up on detergent, it was still on the shelves. I'll go back and look (hey, any excuse for me to pick up much more detergent and FS than I need, LOL), and if it's still there, let me know if you want a box or two. It's a great (if a little sudsy) detergent with a pleasant, not too overpowering scent.
Jeff and David, the 4-vane large-capacity Activator in the Dispensall has AWESOME turnover, so I thought that theoretically this one shouldn't do badly either. Before I tried it, I was talking to Steve R/Gyrafoam and he described this agitator as "worthless." I'd say that's pretty much how it is! Lots of splashing and thrashing, but NO turnover whatsoever, not even on the load of soft darks I put in there (no jeans). Needless to say the ramp went back in very quickly, and the straight-vane was banished to the shelf again. Makes a better decoration than anything, LOL.
Steve, I guess with perforated-tub GEs you either love 'em or hate 'em, especially since they are the polar opposite of a Maytag or a 50's Blackstone (the epitome of smoothness), whereas others (like Whirlpool, Westinghouse, etc.) fall in the middle of the spectrum. If someone likes loud, aggressive, shaky, and splashy machines (like Gary said earlier), then they'll LOVE a GE. These types of machines are my favorite, so I love mine (even if the Dispensall does like to throw water on the machines next to it). The only thing I really don't care about on a GE is the general design. Sure, it may be easy to work on, but other than that, it leaves a lot to be desired. There are MANY leak-prone areas; pulling the inner tub is a must when inspecting it. I siliconed the hell out of mine so it should be OK. With yours, there could be a number of possiblities. Holes in the side of the outer tub, a bad top seal, a bad overflow port, etc. Best thing to do is to raise the top, pull the inner tub, and thoroughly examine any trace of a leak! I ran the Mini-Basket setting on mine, and while it's a little higher than the one in the Dispensall, it's still low and doesn't cause that much splashing. In Tucson last year, I was checking out the water level on Roger's GE, and that one was much higher than usual. When the clutch snapped to 100 OPM, the ramp shot water out way above the lid opening!
--Austin
