wight_rabbit
- Joined
- Jan 4, 2013
- Messages
- 56
Hi!
I posted a thread about a 3314L WashDog that I was looking to own it. Well now £62 lighter I am now the proud owner of this faithful breed.
What I can tell you all in a nutshell about the machine is:
Cosmetically VERY good. No leaks from the spinner or wash tub. The machine is also complete with the lift off work surface which has no marks or scratches.
The machine will spin when the dial is set to MOTOR or RINSE.
The Machine's faults are:
Will not pump out when spinning
Will not pump out when dial set to EMPTY TUB and spinner is spinning.
New pump on internet about £38
Wash pulsator will not work when dial set to MOTOR and timer turned to 4 minutes (or any minutes). Cannot find a replacement motor on web but can find brushes.
Inlet hose is present but has been removed and is quite perished.
The silver inlay on one of the knobs falls out but I have seen replacement knobs on the web for about £2.50
So basically it is a spin dryer that won't pump out at the moment!
