norgeway
Fixing a 1958 Frigidaire Custom imperial in lovely pink!, First, a little background, Ron Jones, our good friend from Rockingham NC, has had this range for a while, it once belonged to, of all people, Billy Grahams Mother!!! Anyway, it had several problems that I fixed, The Heat Minder didnt work just right, well, I found one of the leade from the sensor to the control had a corroded spade clip at the control, A wire brush and a little cleaning set it right, then the speed heat control was about shot, so I replaced it with one from the 56 Model range he got for parts a few weeks back, now it works fine, the clock was a royal pain, when I finally did get it to run , it ran...BACKWARDS!, I switched the sides of the magnets ,curing it, and replaced all of the signal lights with new bulbs, now it lights like a Christmas Tree as it should,,Now the comparison, There is NONE, the only thing a new range will do that this one want is clean itself, Features it does have that NO new ranges have, A meat probe to tell when your roast is done,A Speed Heat unit, A Heat Minder thermostatic unit, Heavy Radiantube Surface Units that laugh at the weight of a canner! a flourescent light,a fused and timed convienience outlet, illuminated controls for each unit,A deep well cooker, A griddle that is made for the Heat Minder unit,a special broiler control for rare med or well done that tells you when your steak is done, a minute timer that you set by turning one knob, instead of touching a miserable touchpad 3 or 4 times for one operation, a glass backsplash that can be easily wiped clean, But most of all, pure old fashioned QUALITY! You dont have to bolt this range to the floor to keep it from turning over!! and you wont burn yourself on it either if you touch the outside while the ovens are on, I could go on and on, after really looking at how the stuff used to be made, What is made today is a big joke!
