fredriksam
As i told in another thread here i was at a friends house and taped some stuff. Like how much it would foam if you put dawn in a washing machine. We did that with a Siemens machine but also with a very old machine.
This old machine, named Värmos was made and sold in Sweden. This actuall model was made about 1957-59. It had no electronics, you had to fill the machine with water yourself and pump it out. The only automatic in this machine is as follows: It has a timer so it wash up to 20 minutes, a thermostat that turns off when the heat is right. Or rather said it SHOULD do that but i dont think it worked tip-top.
So we filled the machine with water and dawn soap and put the temp at the highest marking. It started washing but no foam leaking out at first. We then got to film the Siemens machine and alternate checking out the old machine.
After about 20 minutes we heard a strange sound coming from where the old machine was. My friend got there and seemed to be amazed of what he saw. It did flow a lot so i got there, but then the drum just stopped moving. I had to add more water to make the machine run again. Must have been overheated. Now, here is the first clip. Look at the floor in this clip, it must have flowing for a while
