Old Safety Razors anyone?
washernoob
Jul 3, 2010
1,446
I picked up this little GEM (no pun intended) at an antique store.
$12 sounded right so I said why not. I have always wanted an old safety razor. Would prefer a Gillet double blade but this will do great for now.
This is a 1912 patent GEM single blade safety. I have since restored it. Here are some before and after. I have some shaving lather, a brush, and NOS 1950s GEM blades coming in the mail soon.
I have collected a few. It is fun to find them here and there. Mostly at flea markets or antique stores. The one you have is a beauty. I think you got a good deal on it too. There is a club which is fun at http://www.badgerandblade.com/
also West Coast Shaving for supplies. http://www.westcoastshaving.com/. Good luck with your razor. The double edge adjustable Gillette is the one I use daily. Good Luck, Dano
If they're designed so I can shave once a week and not every other day, I would sure like to obtain one too!
Or at least invest in a new one like this (they're stil made like this, though at a shaving specialty store!)...!
-- Dave
In old houses in the back of medicine cabinets there is usually a slot. I was told that it was used to dispose of old razor blades. I then wondered when a building is torn down do they find tons of rusty razor blades in a pile between the walls? I even had that slot in a medicine cabinet in an apartment I once rented.
I also use the double edged Gillette. The replacement blades are still easy to obtain and are much cheaper than today's blades. My old house also had the slot in the back of the medicine cabinet and actually said blades right under the slot.
The old Gillette Blue Baldes were the best but Dad always said for 1 or 2 uses then toss.  He did have a little machine that had a piece of leather on it and a holder and a crank.  Would put the bldae in and crank and the blade was smothed on the leather like used to be done with a razor on the strap.
And for the Slot in the Medicine Cabinet we had an older house and had to ter into the wall behind the sink to relace water pipes and there was a big pile of the blades from the older steele rusty ones to the newer stainless ones.   This ws in the late 70's.
Washernoob one other thing you need to get is a Septic Stick to use for nicks on your face with these old razors.  Sure saves blood loss ot little pieces of toliet paper stuck on.  Why I use an electric shaver now.  Only do a blade shave once a week.
I have my 5:00 o'clock shawdow by noon anway.
yes it is true
Here is a pic of the back of the medicine cabinet during the renovations at our rental house. It was built in 1941.
My dad was also one to use double edged Gillette blades and razor handle.
I'll never forget when I was in Jr. ROTC in 1971 and an inspection was coming up. My drill Sargent recommended I shave to get rid of the "peach fuzz" my face was sporting. I decided to do this task solo, and was kinda excited about shaving for the first time. I'd watched my dad shave more than once, so I knew exactly what to do. I came out with a clean face and not a cut or nick anywhere.
However, I had to deal with the scream fest the next day when my dad was running late for work and demanded to know who had used his razor.
I went through a phase of using a double edged safety razor. It began in the 1990s. At that time, I was using a Gillette Atra, which had been my first razor. I had huge hassle with getting blades for it. I had bad luck with at least one round of the "real" Gillette blades--expensive, and seemed to wear out almost at once. Most generics weren't much better, although at least they were cheaper. For a while, I used Wilkinson Sword blades, which worked really well. But then the drug store stopped carrying them. (Usual story--find something that works, and it goes away!) I finally decided enough was enough, and it was time to switch.
My switch was to an old safety razor that had been my father's, last used probably early 1970s at the latest. The worst part of the switch was when my mother learned of it. She did not approve of using an old razor, until she learned it had been my father's old razor. (I suppose she was worried about "catching something." I remember some warnings about possibly transmitting HIV by using another person's razor.) But the safety razor worked well for me. I don't recall any more cuts than usual. And the blades were better, and cheaper.
I eventually switched away from safety razors because of the blade availability locally. I went to disposable--which I don't like because of waste, but they are cheap, and ironically seem to often work better than the big buck modern razors. Plus I suppose I have bigger "too much to the landfill" issues elsewhere that would be worth addressing before worrying about a think plastic razor handle.
Although with this thread, I am thinking of seeing what sort of blades I can find locally. I still have the razor. For that matter, I still have the Gillette Atra handle, and even, I think, the safety blank that the Atra shipped with.
