sandy....
i hear you on that cuz i definitely LOVE my 208!!! and the more i use it, the more it is growing on me as it is surprising me with it's abilities and capabilities. and i am really loving it!!!
i was kinda turned off by the fact that it was a "standard" sized washer, but just the other day, i decided to wash the bed sheets & pillowcases. and i wasn't sure how much the "standard" capacity tub could handle, of the load of sheets & pillowcases?
so, i first washed the guest room bedding:
full/double size; flat/top sheet, fitted/bottom sheet, and 4 (standard size) pillowcases.
the 208 washed them well, with extra room to spare in the tub, on a "large" load setting.
next, i washed my bedding:
full/double size; flat/top sheet, fitted/bottom sheet, 3 (standard size) pillowcases, and a fitted/bottom (twin sized) sheet {that i use on my egg-crate foam mattress pad.
again, the 208 impressed me with it's abilities to take all that bedding, i fed into it, and wash it on a "large" load setting, without a hiccup or complaint!!!
so, i am still playing/learning with trying to figure out how much is enough & what would be "too much" for the 208.
i guess i got spoiled with the super size capacity of our other washers & am used to washing all the sheets & pillowcases together in one load. but i know i can't do that with the 208.
so, seeing what my 208 can handle, i wonder if it could wash a blanket/cover without flinching????
what do you think???
