older 60's electric dryrs with two wattage options?
appleimacdude
Aug 13, 2006
3
Another board said something about electric dryers being made in the 60's that had the option of a lower wattage element being used, or a higher wattage one. I posted earlier about having a condo that has only 40 amps juice going in it, and can't add a 220 dryer, or a gas line - and I have been told that converting a gas dryer to a portable propane of liquid gas is not feasible.
Anyone know which models of the 60's - or whenever - had this option, and were these still strictly 220 units -
GE Dryers from the late fifties to the late sixties had the option of connecting their electric dryers to a 115 VOLT circuit rather than the usual 220 VOLT circuit. That's why some of the timer dials went up to 120 minutes; it took that long and then some to dry a load. They also offered the option of using a deflector, rather than a venting conduit on the back of the unit, but no one in their right mind would recommend that today.
Dual heat
Actually, many dryers now on the market can be connected for 115 Volts; they will work at less than half the wattage however, and this will obviously result in long dry times.
Converting a gas dryer to a portable propane of liquid gas is not feasible.
What do you mean by portable? A natural gas (methane) to LP bottled gas (propane) is simply a nozzle/orifice change. Propane requires a smaller opening.
Of course for safety 20 pound bottles of gas (i.e. barbeque size) nor any other size for that matter, should not be used/stored indoors.
Here is a gas conversion kit for a Staber brand dryer.
If it is like their other products it is probably overpriced.
