phillymatt53
Active member
Thanks vac!Hi phillymatt! Our brother in law has a Generac with a Kohler engine. They got it because they had so many outages in winter with hours on end with no furnace. Not a rural area, but the furthest out suburbs. They get the wind and storms from the Flint area to the southeast along the weather front. It was still under the 10 year warranty when it died. The less expensive model has a 5 year warranty. Some reviews also report generator problems. I don't know if they still use Kohler engines, but Toro doesn't. Husqvarna did but I don't think they still make mowers. An aluminum engine under extended load needs cast iron sleeves or an alluseal lining.
They also bought a GE front load combo washer and condenser dryer because of space and she is short and didn't want a stacked set. The motor failed after 2 years. Only parts still covered. When you figure that motor is pulling double duty for a cycle and the drying time is at least 2 hour's it's not surprising.
That clears things up, I was curious about reviews, which most people don't spend time to check out.
I certainly DO check reviews on anything I might purchase.
And I look at the negative (one star) reviews First!
Just like when I worked at the shop - the brands of tv sets, etc that come in, how many, etc.
Panasonic TV's rarely came in the door for repair - so naturally that's what I own.
