Inefficient Perforated Drum Back WP Dryers
Hi Sean, Yes I have to tell that these WP 29" dryers were not great performers in terms of speed or energy efficiency. { and most of you know I love older Whirlpool Appliances ]
They were never rated highly for performance by groups like CRs, the only ones that were rated well for performance were the 9000 watt 50 amp models and the gas 37,000 BTU machines.
WP 29" dryers before 1966 wasted about 25% of the heat whether you are drying a big load or small, probably the reason you are so impressed with your WP Imperials performance is you are comparing it to normally slow MT HOH dryers. Your WP has a 5600 watt element compared to MTs 4800 watt element.
These early WP dryers were sturdy machines that could last a long time and were easy to repair, they were not as quiet as reliable as the 1966 and on dryers however.
About the only better about these early WP dryers was because they wasted so much heat the exhaust temperature was hotter from the beginning of drying cycles so you did not get the condensation and lint build-up in the exhaust duct-work.
John L.
