Well
I think I finally figured out why none of these 50's and 60's MWO's won't work. If the nutrel line is tied to ground it back feeds high voltage simi DC thus shorting out the transfers then blowing the fueses. I tested this Thierry with the 1957 and this 1962 and its spot on. About 4 seconds and bam blown fueses! Un hook the "ground" works perfectly! So with that being said the 62 now works just whating on a pump that I can make work and it will work. John call me when you have time.
