sudsmaster
Or so I thought.
I was doing a load of perm press in the Neptune 7500 this evening. Everything seemed normal until I noticed a funny scrunching noise at the start of every other tumble.
Then I noticed a trickle of water on the floor on the front left of the washer. More water to the left of the dryer (floor must not be real level). Got out the mini shop vac, sucked up the water, and then thought. Hmmm. Maybe I can finally justify pulling the Neptune pair apart and putting one of the 220 volt Mieles in its place (probably 1918). As I pondered this, I shut off the water taps and notice water dripping from the cold water handle. These are kind of odd taps in that they are built into the wall, with the spigots hanging inside the wall space about 2 feet below the handles. A sort of odd arrangement.
I put the Neptune into service mode and stopped the cycle (it was in the middle of the wash portion). Set it to drain, which it did ok without any significant splashing outside the washer. Set it to spin and it did that without complaint.
About five years ago I had to service the hot water tap - same problem, water dripping out of the handle. Now the cold had finally failed.
Drat, probably not the Neptune after all.
Pulled the washer out of the closet, and saw that water had dripped from the faucet handle onto the plastic surround on the rear access panel. It cants outward on the top to accomodate the tilt of the drum/big pulley.
Opened up the panel and saw that a fair amount of tap water had trickled into the washer and was pooling in the depressions formed in the sheet metal. Water didn't feel slippery so I knew it wasn't the latest wash water. The faucet must have been dripping for hours (I did the first wash of the day around noon) before I noticed it.
I'm guessing some of the dripping water was splashing onto the pulley/belt and causeing that funny scrunching sound. I'll know more once I fix the faucet and put the washer through its paces again.
Have to put off fixing the tap until tomorrow when the hardware stores are open just in case I don't have the right gaskets/o-rings in stock here. Don't want to shut off the house water cause the dishwasher is going, and don't want to wind up with a leaky faucet that can't be reassembled (worst case) and not be able to do the usual morning ablutions. One wouldn't want that at all.
So.... doing the perm press load in the Miele in the shop. It's a bit of a full load but the Miele seems to be handling it ok.
And so it goes.
The Neptune that refuses to die!
And so it goes.
