murando531
Hello all,
Since getting the new Bravos, I've been trying various detergent brands to try and wean myself off of using so many P&G products, and I've noticed that the majority of what I've tried so far generate a lot of suds despite their HE labeling. I always thought that the point behind HE detergents was the fact that they are NOT supposed to suds as much. I've learned with this new machine to generally cut the dosage in half from what the directions say, and I get clean, fresh smelling laundry with only a tiny bit of sudsing, but this also complicates things because so much as half a millimeter more in the cap, and I'll have a layer of foam three inches thick, and I have to run multiple rinses just to get it under control.
That said, I wonder if this is an issue any others have found with modern detergents, especially front-load users, with their even lower water use. So far I've used Tide and Gain of course, All, Wisk, OxiClean detergent, Tide Pods, and Purex, and of those, the only ones that don't cause as much of a problem and still give good results are powdered Tide or Gain. I suppose at this point I might as well choose the lesser of two evils and stick to the Tide and Gain, but it would be nice to be able to change it up now and then.
		 and have been pretty impressed with the results so far.  Another customer in the store grabbed a bottle at the same time I was looking at them and mentioned this was now her second bottle of the stuff and it was really good.
