Paging the Hamiltons!
Nice score!
Very interesting set. That washer is cool. Love the turquoise tub ring, agitator and accents with the dark speckled tub. The filter and bleach dispenser look Blackstone, the fabric softener dispenser looks WCI/Franklin and the agitator almost looks Norge-ish.
more under the hood.
More of the washer. How does one tell the manufacturer? The dryer is Hamilton, but not sure on the washer. The fabric dispenser looks Whirlpool, but also Norge.
I never thought turquoise, and coppertone would work together. I still don't think so.....
[this post was last edited: 6/12/2016-11:52]
Kenny, thank you for all the photos.  I would like to request if you can take photos of the control panels such that we can read all the wording and descriptions?  I realize the panels are shiny and might have reflection issues.  Also photos of the underside of the lid with the programe chart with cycle descriptions and options programmed into each of the cycles.  I just noticed the cycle knob has numbers for each setting.  Thank you.
Dryer inside
Like I remember all the Hamiltons over the years. Galvanized steel drum, Sun E Day ozone lite.
Now the story, as I know it. These were in the basement of a quad level house on South Bend's west side. Average middle class neighborhood. There was an estate sale going on. Talked to the guy running the sale, he said the daughter of the owner told him that her mother didn't like using them, they were seldom used. She liked going to the laundromat, and meeting up with her friends there ! The dryer was still hooked up, but the washer was disconnected, looked like for quite a while. The fill hoses were still tied up. I made an offer, and took 'em home.
Anyone else have this washer or dryer? I'm curious as to the year of manufacture.
washer pics behind and under
if you can get pics of the washer mechanism could tell who made it-motor spec tag might have a date code to reveal general timeframe of manufacture :)I'm still thinking ~1968-70 franklin.IIRC,this franklin design makes an oinking sound while agitating(or am I thinking of an earlier franklin mechanism...)
John could very well be right about Blackstone because Blackstone did make Hamilton solid tub washers in the mid 1960's. Blackstone washers of this era had ribs in the basket, it will be interesting to see for sure. They both look hardly used, it must be coppertone month! I would love to find a washer like that sometime to try out.
GE motor
GE motors usually have a date code stamped into the endbell along with the other specs-I'll check some of my spare GE motors to see how the date code is configured :)Will be interesting to se if these machines operate well after the long slumber.
What an awesome find! Beautiful!
The dryer drum is fantastic!
Where is the Gas Burner on the dryer? Does it state how many BTU's the burner rating is? I am curious also to what type of gas valve is used. Wonder if it is a White Rogers Modulating gas valve?
What a fun set!
Congratulations!
I do remember a lady I know who had almost this exact set. What I find interesting is that the set she had must have been a year or two newer than these because her dryer did not have the perforated drum. It had a solid drum like the more conventional dryers of the day and the lint filter was right in front when you opened the dryer door. The door on her dryer had the big glass insert that covered most of the dryer door too and was the same width as the washer. So they did finally change the dryer design. I have had both styles of Hamilton dryers and I can see why they changed the design. It must have cost a fortune to build the old style ones. The had an entire outer drum and inner drum like most of the perforated tub washers do. Hamilton never built their own washers. First Norge built them and sometime in the sixties, Blackstone started building them. Not sure about this design. I did work on the one that lady I knew had. It was different than the Franklin made machines of the same era, so I really don't know what it was. I had to replace the pump on her machine and it was different than any other machine I had ever worked on. The pump actually attached to the motor like the westinghouse or frigidaire 1-18 machines. That much I do remember and had a circulating filter built into the pump.
