Sorry Jeff, but I think you're mistaken
Baking is a method used by manufacturers to force dry the paint. The cost of those ovens is reduced to virtually nothing when you consider the shear volume of autos passing through them. Catalyzed enamels are much more expensive than non catalyzed, so costs would rise with their use. On the other hand, body shops make use of catalyzed enamels because you can't put an assembled auto in the oven without doing serious damage to all the rubber and plastics. This is true for appliance manufacturers as well. It's less expensive to build an oven and pass thousands of cabinets through it than it is to pay for catalyzed enamels for those same cabinets. It all comes down to scale. So unless Freddy, or anyone else for that matter, has access to an oven large enough to stick a washing machine cabinet in, the best we can do is catalyzed enamels. Just plain old heat lamps on a stand won't make the paint any harder. They just speed up the drying process. So if you aren't in a hurry you can do without them.
