panasonic microwave oven repair
gizmo
Nov 17, 2001
2,604
Victoria, Australia
I have an oldish Panasonic microwave oven, it is a model NN-5558.
It has been a great machine, it is the only micro I have used that can defrost a small quantity of food (using the defrost-by-weight feature) without cooking the food, just defrost it to perfection.
Now its timing is playing up - quite often the time countdown on the display will freeze, when it does that it also doesn't respond to pressing the stop button, if it has frozen I have to wait for it to get its marbles back and start counting again, or switch it off at the wall.
I imagine the problem is something simple like a dried out capacitor that needs to be replaced. I am OK with PCB repairs, but have no circuit diagram and no idea where to look.
I'd like to keep the old girl going if possible, any suggestions?
If I decide to replace it, any suggestions re Sharp vs Panasonic? (the two preferred brands, or other suggestions.)
I'm not interested in fancy functions such as sensors, I rarely cook with a micro, all I use it for is mainly defrosting and reheating.
Lower power consumption is good as we are on solar power. So I'd be looking at a very basic model.
I would be very cautious about fiddling with a microwave oven, due to high voltages, charged capacitors, and the need to ensure that there is no microwave leakage when reassembled.
Might need a new control board, best to contact your local Panasonic repair centre.
my '82 Pennys (Panasonic) needed a new 50v 470uf
I just took the board with the VFD (display) off and found the smoked cap. These are all LV parts. After replacing 4 of the caps I put it back together. The VFD is still weak but the cpu board works.
I keep the parts at my computer.
Here you can see the burned up cap on the lwr left.
Another view, still a bit fuzzy
Note: you may disappoint some people if you repair one of these large old microwaves. Sometimes other members in a household anticipate the failure with joy. They do take much more room than todays units.
go figure
