For certain things will haul out one of the Hurley presses.
Contour/fitted bed sheets are easier done on a press rather than fighting to get them through an ironer. It does vary but those with elastic all way around edges are a chore to do on an ironer, but easier to do on a press, especially if folded into quarters.
Commercial laundry workers refer to positioning things on the press buck as "lays". Depending upon what is being pressed and the size of the buck (the ironing board part of the press if you will), and how it is shaped you can be moving things around quite a lot. Trick is to know how to go about things so you don't muss up sections already done when moving on.
When you are ready to run with the big dogs:
