Parnall SpinWasher De-Luxe 1966
chestermikeuk
May 29, 2001
7,410
Rainhill *Home of the RailwayTrials* Merseyside,UK
We had a mini meet recently to overhaul the Parnall SpinWasher semi-automatic top loader, I had a phone call from a lady in Somerset who at 70yrs young was downsizing, She told me when she first married her mother-in-law gave her this and she used it for nearly 10yrs with young children until she traded in for Bendix 7147 autowasher as she needed an automatic because she was a working mum. The Spinwasher had stood in her garage (and had been used a a spinner when she had problems with new washer) until she contacted me. She couldnt bare to skip it so wanted it to be preserved!!
Inital fill & test proved needed brake shoes adjusting, new motor capacitor, tweeks to the Selectromat control valve, re-fitting a nut and bolt in the perforated solid tub liner as it was leaking and usual new pipes etc..
Parnall Spinwwasher De-Luxe EWH601H
The Parnal Spinwasher is a perforated liner solid tub top loading semi-automatic washer. Its the later incarnation of the Thor Automagic, it has the ability to spin and store the wash water in the outer tub so you can remove one load add more and re-use the washwater. The 3kw heater is placed in the outer tub so you can fill from your hot water or heat it in the washer. The 2 pipes on the top are for (viewed from front) RHS - Drain Hose, and LHS Fill Hose.
The unique feature of the Spinwasher is the "Selectromat" control valve which controls and mains on / off / motor function / agitation & spin mode and a water valve which controls the water from the washtub and outer tub, ie spin to drain, spin to save, heat water and pump to inner tub, suds save re-use.
