<span style="font-family: helvetica;">The main issue I have with using it is I never seem to see the posts until the next day when its moved on to something else. I understand they are random but I wonder if there is or has been any consideration to setting it up with some kind of history, so we could plug in a date and see what was listed on that date.</span>
<span style="font-family: helvetica;">Or is it an option to give us a button we could click in the message to fill in the URL to that day's POTD so if we're looking at it on a different day we could use the URL to get to the one that is referred to in the message. Maybe something like click this button to fill in the URL to today's POTD?</span>
10/14/2021 -- Whirlpool, toploader with variable-speed direct-drive motor, dated 10/18/1966. Apparently the first time I've seen this patent as I didn't have the file saved.
10/17/2021 -- Bendix Home Appliances, dated 10/22/1940, frontloader with an automatic soap dispenser that utilizes a light sensor to determine the suds level in the drum for adjusting the dosage per water conditions, load sizes, and soil levels.
Thu 11/11/2021 -- Catherine R. Thomas, dated 01/28/1969. A washer with ability to wet and fast-freezing a garment, which is then thawed and washed normally as a method of handling difficult stains. The freezing and thawing process loosens stains that resist removal by conventional treatments.
Sun 11/21/2021 -- Pat 3,060,713 10/30/1962 is missing a description/text page. Does anyone recognize what brand with which it may have been associated?
Sat 12/18/2021 -- General Motors, dated 03/21/1961, combination washer & condensing dryer, fully front-serviceable so as to be suitable for undercounter installation.
I never knew GM Frigidaire even considered jumping on the combo washer/dryer wagon back in the day. No window in the door -- did Maytag copy this for the Neptune? LOL
Sat 01/08/2022 -- General Motors, dated 04/14/1959, toploading combination washer/dryer, with the tub changing orientation from vertical for washing to a horizontal angle for tumble-drying.
Thu 01/13/2022 -- N.B. Wales, dated 01/13/1948, combination washer/dryer, with the drum rotation via a "blast" of air aimed at scoop-vanes on the exterior circumference.
Mon 01/17/2022 -- The Hoover Company, dated 09/03/1974, combination washer/dryer in which clothes are "hung" for washing and rinsing in a compartment with a spray arm, and drying via fan-forced airflow.
Thu 02/10/2022 -- Westinghouse, dated 05/05/1970. If I'm understanding the description correctly, it's a mechanism to insure the spin basket rotates (indexes) in only one direction during agitation to avoid bi-directional indexing from impairing load rollover with a ramped agitator.
Sat 02/12/2022 -- R.H. Whiteley (independent), dated 05/31/1938. A dual-impeller washer with optional/removable mesh basket (presumably for delicates), and a wringer head and/or a twin-tub style spinning extractor.
Sun 02/13/2022 -- Mathew Hurwitz, dated 02/25/1975. Toploader using a water nozzle agitator. The feed tube seems an obstruction to loading/unloading. Apparently has Whirlpool roots, although Whirlpool is not stated as the filer or directly mentioned in the description.
Sat 02/26/2022 -- Federal Telephone and Radio Corporation, dated 06/30/1953. Frontloader vibration-resiliant door seal design. Related to Westinghouse slant-fronts?
