Perfect restoration of a vintage Maytag washer
Thanks... I figured that it would make sense that he would be a member here.
This video is amazing, the music, the work that goes into this restoration.
Great work, Eugene.
Sorry, meant to say I wasnt sure what he replaced on the brake package. Oil was related to trans, synthetic or regular. I would assume synthetic after going through all the trouble of a quality resto like that.
Oil
I used Maytag oem gear oil. I was chatting with another technician on a different forum and he said he tried using synthetic gear oil but was too runny and was passing through the lower o-ring seal.
If it needs to be replaced every 30 years that’s ok.
I did rebuild the brake, not much to it. I neglected to oil the brake the first time and ended up re doing it 2 more times. I finally used some leftover gearcase oil and that did the trick.
Thank you all for the kind words. I hope to do another Maytag in the near future
