sudsmaster
It's true that laminate flooring can't be refinished. But it's probably cheaper and quicker simply to replace the entire floor with new laminate than to refinish the same size hardwood floor.
When I bought this '41 bungalow in '97, I ripped out the tired wall to wall and found nice oak hardwood in three of the rooms. I rented a sander and refinished them myself. It wasn't easy or quick, and there are still some spots that I'd rather not look at
. But of course I love hardwood. In the master bedroom, however, the carpet was laid over the plywood subfloor. I lived with that plywood for about five years (covered up most of it with area carpeting), but finally replaced it with "maple" blond colored laminate. I chose that tone because I don't like the look of fake oak laminate, and nobody's going to mistake the "maple" laminate for the real thing, either. It is very durable and easy to clean, though. It's like having light yellow/tan flooring of some indeterminate nature. No worse than vinyl in terms of looks. Putting it down was fairly easy, although I had to redo the baseboards (bought and painted new ones).
It is a bit noisy... I have a cat that has extra toes and you can hear her click on the laminate at night. But she also makes noise on vinyl flooring too. Also the laminate I installed has a separate foam underlayment, which in certain spots makes a little clicking noise at certain times of year, even when walked on with soft soled shoes. More modern stuff can have the foam attached directly to the bottom of the boards. Supposed to be quieter and sound more like "real wood".
