murando531
Hey guys!
I could have sworn that I posted a thread about this and searched for almost 30 minutes and couldn't find one. I think maybe I started typing one and then never posted or saved it. I apologize if this is a bit lengthy; I've been meaning to ask these questions for a while but never got around to it.
Anyhow, in just a few months I will have had my Maytag Bravos XL for a year, or a year and five months if you include the first one I had that had a bit of...drama. LOVE this washer, haven't had a single peep out of line from it since day one. I really want to keep it that way for as many years as I possibly can, and if I decide to get another machine, I'd like it to leave here in fine shape for whoever inherits the "BravOasis".
I guess to start with, to give an idea of usage habits, I am very particular about loading it to make sure the risk of a badly balanced load is minimized. I also only use the Medium spin speed, which probably tops out at around 900 rpm or more in the last couple of minutes, compared to Max Extract which is the full 1100 rpm for the last three minutes. Even with heavy loads of towels, everything comes out very damp dry, and the dryer has no problem, so it just gives me peace of mind that I'm not adding unneeded stress to the bearings.
I'm also pretty conservative with detergent and fabric softener, using half of the measurement I would have with the traditional washer, and usually no more than the first line on the softener cap for a full load. I rarely use bleach because of concern over corroding seals or the shaft, and if I do use it it's no more than 1/4 cup vs. the instructed 1/2 cup for an HE washer. Seems to be the perfect amount for my needs.
As far as cleaning, I always keep my appliances polished and finessed, but I actually haven't used the Clean Washer cycle very much because the thing already keeps itself spotless. I've never had any grime or residue remaining on the basket walls, and never had anything other than a nice clean smell if you take a whiff in the empty machine. I think because of regular use of hot water on the PowerWash cycle with full towel loads, which is NOT tempered down, the recirc spray, and the fill height for that size load each time, any residues that could accumulate are kept to a minimum.
There's all my "habits" so far just for informational purposes, but at the almost year mark, I'd like to make sure that I'm doing everything I can to prolong the life of the machine. The biggest concerns I've read or heard of this design are the bearings and the drive shaft corroding, so I guess that's really what my big question is.. Should the inner basket be removed every X months for cleaning and relubricating the drive shaft, and what lubricant should be used? And is there anything as far as spin speeds, or detergents/softeners and bleach/Oxi that I should be more particularly mindful of that could hurt the bearings and seals? That's really the only thing I can think of, these machines being relatively simple in the grand scheme.
As always, thank you to anyone who can give advice. It is ALWAYS appreciated.
