PHILIPS series 90 Dryer Economy
twintubjamie
Jul 14, 2011
Telford, Shropshire, England.
Hope someone can help, this dryer which is in good full working order and in use. needs a vent hose which comes out of the front at the bottom of the machine. Or the attachment that goes in so a vent hose can be attached, or any ideas of what could be used
Philips series 90
Hi Jamie, if you take the back off the dryer there should be a concertina hose and a diverter which direct the airflow front or to the back, if its going through a wall vent you can get a generic vent to fit, if you do want to connect to the front vent you will need the y shaped adaptor plate, which are a little difficult to find..
I set up several of these in Germany
A few thousand years back (wouldn't be surprised if they're all still working).
There is a standard connection possible through the rear. Sort of like those Hotpoint/Candy vent hoods which can be vented in virtually any direction.
Sharp edges ! Be sure you don't cut yourself or the wiring.
