You're right under certain aspects...
The speech about vintage machines with alumimum parts is different though, of course is safe to use stpp, not strong basic stuff, so basic solutions . Vintage machines that used to be made before the" modern" detergents, so the ones that used to be made with exposed aluminum vital parts like agitators or even shafts etc (that were anyway made with alloys standing well medium basic conditions) are not the best to be used with stronger basic/alkali solutions or additives creating such stronger basic conditions, as they were not meant to do so due to formulations of old detergents...the new ones may provide bad oxidation of said aluminum parts and may also corrode them in the long run, use after use ( with stronger alkaline wash waters solutions), I could just see my vint age Servis' twin tub shaft getting slightly marked with the white patina and by white points by using some perborate added to regular detergent, perborate which created a stronger alkali solution when has been added to a crappy detergent that was already full with alkalis (much washing soda) that I ignored it was... infact now that I know I will only use certain types of powders...I also didn't realize it's shaft was made with that delicate aluminum alloy.. if i have to be honest, so didn't even worry about that.
Infact back then as you mention, the most common type of detergent was plain "soap" flakes or powdered form, and some time later new syntetic detergents came out, from what I know though initially were not loaded with as much alkali as are now getting newer powders, they had more active stuff (surfactans) and less "boosters" like washing soda , this changed during years and especially now after that many ones tries and tried to replace STPP function with a greater amount of sodium carbonate, adding anyway slightly more zeolites supposed to act also like STPP for metal protective caratheristics, but not just as well and as effective.
I can though confirm you at least from what I could read that oxy bleach stuff ( I mean the non perborate oxybleaching stuff, perborate is actually a basic/alkali ) can oxidate it, this is why I can read even on color safe bleach (hydrogen peroxide main ingredient) bottles to do not use it on aluminum.
I get what you said about my speech.....of course a stronger alkali solution may be bad for a vintage machine like would be a beatty wringer or an old vintage speed queen with aluminum agitator...so you have to be careful what you use in, that must not be necessarily a detergent of the era in which it was made...you just have to be careful about the powders and the alkali percentage they contain to avoid irreversible oxidation of it's vital parts.
I think newers like the Neptune you mention do have another alloy for their components and what you get is just an oxidation and not a danger of corrosion even in strong alkali solutions (just do not know about this, but would be really weird if not so) ..but vintage ones with such parts were just not meant to deal like that with stronger bases, here why you have to be more careful.
From what I know machines made after, were just meant to stand basic solutions....came after the newer syntetic detergents boom.
Probably some would not even suffer if you hypoteticaly use pure lye as wash water... but that would reduce your clothes like toilet paper so that's not the case at all....
They all can deal with sodium carbonate,perborate etc.... and these kind of alkaline stuff in fair doses and concentrations without any harm..... not the vintage machines with aluminum parts, there is always the risk to permanently ruin (for ruin I mean even a darkening oxidtion) a vital part, agitator etc...not to mention if you're usual to wash in stronger bases, for example by adding perborate to everyy wash with a powder already containing carbonates in modest quantity, that may even give life to corrosion (meant as progressive thinning and "holing", not the oxidation you said) in the long run.
All I know is that acid like basic solutiuons are dangerous for aluminum, ....and usually basic/alkali solutions are the conditions detergents creates...some more and some less....
I know what you meant, the aspect of a vintage machine with aluminum is important also..... I just said it wrong by saying any machine before, I left this matter of vintage machines and their aluminum parts for granted, but better to make the point about that!
You're right!
[this post was last edited: 7/7/2013-15:42]
