Stevet
I am working now in a restaurant with a Meiko Machine. I really have to say this , but What a piece of crap. You would think a machine made in Germany (My native backgound and Mercedes, and BMW )The machine would be fantastic as far as the engineering would go..The machine cleans unbelievably. Choice of three wash programmes.(Especially for a Breakfast Restaurant with dried egg yolk etc.)They built the machine with very heavy gauge stainless steel. The wash arms are very well designed for the spray pattern. But...The manifolds feeding the upper and lower wash arms are made of PLASTIC. !!!!! Can you imagine the abuse these machines these days from dish handlers slamming sheet pans (18x26) into that machine and cracking the manifolds ? My last tech that has repaired endless issues with circuit boards told me to replace the upper wash manifold would cost $750.00.
As far as the newest Hobarts go, I see the same technology as far as the machine will not rinse or stop washing until the temp hits the specified sanitizing temps.
Give me the Cam Timers,Cast Iron Wash Arms,Hatco Boosters along side of the machines,the Buss Fuses,and Manuel Fill Valves and NOW YOU HAVE A GREAT MACHINE. Just my preference.
Do you remember the XM models ? I was going to a summer camp where they had a XM with the HUGE motor mounted on the left,(I belive it was a 2 HP motor) The R-1 Crescent reducer in the center to drive the conveyor and the Pump at the far right all connectected together the whole length of the machine ? Of course you had your choice of right to left ot left to right in your specifications on the machine being built for your dish area specs. It also had a control arm that you had to press down to push the last rack out. This was located just under the inspection door that would let the rack "Dwell. " Stay in the center of the wash action for a type of "Soak and Scrub". The name plate on that control arm that you pressed down to get that last rack out was "Hobart-Crescent Dual Drive". How that for a memery ? I believe Josephine Cochran sold the Dishwashing machine to Crescent and than it turned into Hobart. It even had a small "Port Hole" in the Inspection door.It was so cool to watch the spray action of the machine as it was running. When you fired that machine up all you heard was a low hum of the motor and water spraying. The Top spray was a three arm revolving wash arm while the lower one was stationary. All made of NiResist and the revolving wash was external ball bearing mount. Wash Gauge was on the Left,Rinse on the right and you could see the ball bearing mount for the upper wash exposed to see if it was rotating. This machine resembled the C-44 except I think it was 36-40 inches in length and had rounded hoods on either end. What a machine they built back then.
Then there was DuBois Chemicals. They had a soap called "Kloro-Kol". A chlorinated powder that went into the "Viz-a-trol" Soap resevoir and was dispensed and the "Rinse-a-Trol that dispensed the drying agent. It had a piston pump that lit up every time a rack went though the rinse section of the machine. The Viz-a-Trol had a electrode in the tank that sensed the titration (sp?) of the detergent in the tank. What a great aroma of that chlorinated detergent. It smelled so clean as the dishes passed out the end of the machine, in the old Heavy Stainless framed Sani-Stack Racks with the Plastisol 7 compartment Plate Racks, The Compartmented Glass Racks and the "Flat Racks for Silver ware."
Those were the days my friend. Lots of energy used and Lots of Hot Water. And great Results. It has been a fantastic pleasure running into you and everyone else on automaticwasher.org. I'm thinking about your offer. it's mild up here but maybe I'm ready to make a change. Please stay in touch.
Oh by the way, I don't care what the cost is for that drain valve, I'll maybe have a tech do it for me. I can do the little stuff, but the KD2 means so much to me, I need to see her up and running practically as my daily use machine. Fond memories brought into reality...I can't put a price on that. Eddie
