Fantastic pie crust
From a Sister Cities International cookbook. Have used it for years.
1 1/2 cup flour
2 tbsp cold milk
2 tbsp sugar
1/2 tsp salt
1/2 cup oil
(for an 8-9" pan; for 10" pan, increase to 1 3/4 cup flour, 2/3 cup oil, a bit more sugar and milk)
Mix all ingredient in a bowl until it forms a ball. If too flaky, add a bit of oil. If too gooey, add some flour. Should have a Play-dough consistency when mixed properly. Throw it in the pan, flatten with your hand and work the dough up the sides of the pan. Flute or apply a fork pattern as desired. Fill and bake for an hour. Dough can be chilled and then rolled between two sheets of wax paper for a two-crust pie, but for single crust pies, just pat it out in the pan and skip rolling.
For recipes that require a pre-baked crust, you may pre-bake and then fill, as long as total cooking time doesn't exceed an hour. Example: my pecan pie recipe takes 35 minutes to bake. I pre-bake the crust for 20-25 mins, remove and fill, then continue baking for 35 minutes. The crust needs an hour of cooking time at 350 F, but it can be divided between pre-bake and real bake if needed for the recipe you are doing.
You can substitute whole wheat flour and it gives an almost graham cracker crust taste and consistency, but in general a bit more oil is needed than with white flour.
<span style="text-decoration: underline;">Note: I has served pecan pies to visitors from the South without telling them the ingredients, I only say that it's made from scratch. Most of them are convinced it's a butter or Crisco-based crust. Only after they ask for seconds do I reveal it's an oil crust. No, they don't dial Poison Control or 911. </span>
