dangerboy
I have a Canadian made 1956 GE Speedster range model no. CJ405NA1W. I think it's pretty much the same as the US made J405 of that year except for maybe a few small differences here and there. One difference appears to be that the Canadian factory sourced its oven thermostat from a Canadian company, Oak Hart Mfg. Canada Ltd. and I think the US Factory probably used a US made thermostat/control.
The oven has two control knobs. One sets the baking temperature and the other is used to select Off, Bake, Time Bake or Broil.
This range has been in the family since 1973 and I am almost 100% certain this is the original thermostat for the range. The markings on the thermostat are as follows:
30A 115 - 230V AC Only
Cat. No. 891A1 15H M
Oak Hart Mfg, Can. Ltd.
On the back of the thermostat there are four screw terminals marked as follows:
1 | 2
L | L1
I have the thermostat out of the oven and the oven is 400 miles away at my cabin which I won't be going back to until next spring so I'm trying to figure a way to determine if the thermostat is still working using the oven I have here and a multimeter.
The reason for this is that I suspect maybe the thermostat is working and the problem of the element only heating to slightly warm is due to something else. I suspect the thermostat may be working because I took it apart and put the sensor into a working oven as it was heating up and measured the height or width of the bourdon tube piston thingy (technical term) to see if there was any change when the sensor was heated up and then cooled down. There was 3 or 4 mm of expansion going from freezer temperature to 400F so it looks to me like there's still gas or mercury in the bourdon tube and that part of the thermostat is intact and working.
Attached is the circuit diagram for the range. Can someone please help me understand how the thermostat is supposed to work here? I think I have it figured out but I'm not sure.
At room temperature, I have continuity across contacts L and 1 and L1 and 2 but no continuity from any of the terminals on the left side to any of the terminals on the right side because the elements are not in the circuit.
What's supposed to happen when the oven gets up to the set temperature? When I had the thermostat apart and pressed on the metal spring plate that sits behind the bourdon tube piston thingy, I got continuity between the right and left sides of the thermostat box. Based on that, I'm guessing what happens is that when the bourdon tube piston thingy expands far enough, contact is established between the 1-L side and the 2-L1 side and somehow that shuts the current to the element(s) off until the oven cools enough for continuity between the two sides to be broken and then current starts flowing through the elements again and the oven begins heating again and so on.
Is that how it works? If yes, why does the current stop going through the heating elements when continuity is established across the thermostat? Is it because a path of lower resistance has been created across the thermostat and the current goes that way instead? That seems plausible to me.
In that case, should I be able to test this thermostat by setting it at 350, sticking the sensor bulb from this thermostat into a working oven set at 400 and then checking to see if I suddenly get continuity between L and L1?
1 | 2
L | L1
