My buddy has a double sink with disposer on one side.  The disposer sink backed up but curiously (to me, anyway) the other sink still drained fine, and that is the side that has the P-trap and connects to the sanitary line in the wall, everything being PVC.  It was easy to conclude that the clog was located in the horizontal section between the disposer and the vertical section from the regular sink, and it was easy to loosen the connections at both ends for inspection.  This is when I discovered an odd fitting I never knew existed, but certainly explained why the side without the disposer would still drain.
I've attached a couple of pictures. The fitting that ties the horizontal section into the vertical above the P-trap is divided in half inside, which means both sides have their flow restricted when passing through this fitting just above the P-trap. This may be OK for the side that just has a strainer, but it's problematic for free-flowing content that the disposer has processed. This half-and-half fitting is where the clog was located.
While I understand the logic of one sink that drains is better than two that don't, I'm wondering if this is proper when a disposer is involved. The clog amounted about a tablespoon of muck. With a full-width drain, it would have been dispersed.
Since it's in an apartment, nothing can be done other than running a lot more water after using the disposer, but I'm curious about whether the pictured fitting is supposed to be used when a disposer is involved.
The photos have been turned on their side by the attaching mechanism here, and these are views of the vertical section. You can see the flat piece that runs through the center of the fitting, forcing a hard 90 degree turn for waste from the disposer.
