wft2800
It has to be said, I rarely need to top up the water level on my 2005-vintage Miele, the 'Water Plus' option is quite enough... for heavier loads (stuff like big bulky bedspreads), I will use either the Delicates 40 wash or the Separate Rinse to fill it before selecting whatever cycle I use. Bear in mind, European FLs need time to heat, with a maximum temperature of 90-95c (even a full 100-105c in some vintage machines). Even with hot water on tap at 60c (which is as hot as any non-heated US washer is going to get), that takes quite a bit of heating... a 10-minute wash time may be just enough if you're treating your laundry with a load of phosphate detergent and bleach (both highly toxic - the former is now banned in the UK and throughout Europe), but you're creating a load of problems for yourself and the environment. Even after loads of rinsing (e.g. my old 90s Bosch does FOUR deep rinses), the laundry still smells of bleach, if I've used it (dirty whites tend to need a bit). Consequently, especially as the wash water has usually ended up pretty filthy, I always send it round a second time without bleach.
Most of the vintage European machines spun out fully between rinses - the big Bosch was the one exception to that. I've just glanced at videos of an AEG Lavamat Nova and a Miele 421 - both spin out before and after every rinse.
