Thanks, Ben. I knew the new trannies were not introduced across the 06 line at first. It was just that the agitator in the ad was so shiny that I thought the high gloss was due to it being poly and, of course, they did make the narrow post Gyrator out of Poly for the wringer machines. John has an early turquoise large cap agitator that is still of the design with the double skirted base like the Bakelite lint filter/detergent dispenser agitators introduced in 57/58(?).
I tried running a Gyrator in my 806 with the original 60 cycle pulley and it was a total mess. It did nothing to improve the turnover. All it did was set up huge waves and got the load so balled up that it had to be redistributed at each drain when it went OOB.
My baby A102 now has a commercial standard cap. Black Poly with set screw in it. With the 50 cycle pulley and the old pattern of holes with the tub solid opposite what was the Gyrator fin area, the agitation is outstanding; not at all like a Maytag.
"The A106 and A206 were originally built with the earlier gear set to produce 54 OPM" So it was not really a washer comparable in performance to the rest of the 06 line.
