POD 11/13 Easy.....
alr2903
Mar 5, 2003
5,271
TN
.... stunning pair. Direct drive, lighted panel, window door in the dryer. Was Hupp the last owner of the Easy brand?
Easy Solid Tub Washer
WOW you can see the lengths they went to to try to keep small clothing items out of the outer tub and water pump. I think that they knew how fast it would burn out the crummy Westinghouse motors these washers used if a sock got jammed in the directly driven water pump.
Can you imagine the stinky mess that big plastic screen in the outer tub would get in a washer today with all the non-phosphate detergents washing in cold water, LOL.
Cool Washer though.
I had one of these at one point in time. It was a very good machine and the only reason I got rid of it was because of ignorance in my youth and not digging deeper into finding what the problem was with it. Apparently there must be a coupling, much like the Whirlpool direct drive machines, that connects the motor to the transmission that must have broken. When it quit working at all, other than the motor running, I pitched it.
