POD 5/14/2017
brucelucenta
Jul 21, 2013
1,924
Norge was big on promoting natural gas appliances. The dryer pictured, was the same design Norge used for many many years and was fairly large capacity. It was still in use after they came out with the large capacity washers in the early 60's and did not change until much later. That same dryer design was common to see at many used appliance stores during the 70's and even 80's. Those dryers long long long outlasted the washers they were mated with and were really good performers with little problems. The gas models were some of the fastest drying machines I have EVER used in my life! It's a shame that Norge washers were not as durable as their dryers.
I never saw one of those hair dryers...
<span style="font-size: 14pt; color: #008000;">As someone who worked on many Norge dryers, both gas & electric including the model pictured, I'd be equally concerned about lint. There's plenty of places a small amount of lint could accumulate in the air flow and work it's way loose while a lady was drying her coiffure. How embarrassing to have the girls at the bridge club whisper behind her back "hasn't she been told about Head & Shoulders in the gallon family size?"</span>
We had a Wards / Norge washer and dryer when I was growing up, and you are right as they dried huge loads about as fast as anything we ever owned. We had the 20lb. washer and it was nothing for that dryer to handle. You could be done with laundry in no time. Huge tub. Excellent dryer.
Here's more of my 2-cents worth...
<span style="font-size: 14pt; color: #008000;">These were excellent dryers. Not only did they dry fast, but they did it using a lower cycling temperature. Dryers use two things to dry, heat and air. Norge used more air. If you've ever taken one of these old units apart (Timelines were the same) you would see that the blower fan was huge. The drum turns on rollers instead of a pulley. With the back off it gives you an optical illusion that the drum and the fan are turning on the same shaft in opposite directions.</span>
<span style="font-size: 18.6667px;">Air enters the dryer through three ports at the back end of each drum vane effectively blasting the clothes with air. The drawback is the fact that these Norge dryers worked in reverse. Heated air was blown into the drum instead of sucked out. As the dryer aged, the door seal and the seal around the "pain in the neck floor-mounted lint filter" leaked moisture-laden air. If the dryer was in a garage it was no big deal, but in a laundry room it was a different story. All of the paint in my mom's laundry room peeled off the walls. And when it came to replacing the door seal it was awful. The seal was held in place by a wire loop that was almost impossible to replace.</span>
<span style="font-size: 18.6667px;"> </span>
<span style="font-size: 18.6667px;">I'm sure all members are tired of my trips down vintage-appliance memory lane, a time when I was young and didn't need a cane to walk to the bathroom.</span>
twintubdexter
Nothing wrong with a stroll down appliance memory lane, we remember a lot of things others have never seen up close and personal. Norge is just one of the many things. They really dried clothes well and quickly. Too bad that the door and lint trap seals would let lint and dust escape as they got older. They still worked just as well, but you had a LOT of lint in the area the dryer was in.
