POD: 8/26/2019
brainardcooper
Jul 16, 2013
203
Columbia, SC
You cannot put a Revere Ware pot, pan or skillet in a dishwasher and expect the handles to maintain their shine (or a Corning Ware electric coffee pot). The woman in the picture will have to learn the hard way, just like I did...
Over time, oven heat, if the pans were regularly put in the oven, would dull the shine of Bakelite, too. Most of the women who had dishwashers were thrilled that the pans could go into the machine and did not worry about the handles. Cast iron skillets were about the only cooking utensil that did not go in. It was amazing how fast, once a family got a dishwasher, that the copper bottoms on cookware stopped being polished after every use. It probably was not just the dishwasher, but the loss of the novelty of the shiny copper and the whole, "I'm too old for this" attitude put an end to the polishing. I watched neighbors who had the Cameo under the sink and always pulled it out as the last step before rinsing the pan when doing dishes by hand and after they pulled the clean, dry pans out of the dishwasher, it was like starting all over again to polish the copper.
Did the old impeller dishwashers clean well? Don't recall any impeller style that had an upper wash system. Was there a lot of pre-rinsing? Thought it was really cool how one loaded those dishwashers, sort of in a circle.
Was it KA that first came out with the spray arms?
Barry
They could, but you have to remember that these first & second gen machines did not have much in the way of detergent dispensers so that meant mostly one main wash followed by the after rinse or two. GE & Hotpoint did have dispensers and a prewash or rinse, but no drain that ground up food waste like later dishwashers did. The Bakelite impellers were not as sharp as the metal ones so they did not throw water as forcefully. No prewash or rinse meant tubs were not adequately heated up for the wash. These machines were not meant to scrub, but to wash off fresh soil and not heavy soil because they did not dispose of solid particles too well. This GE, for example, did not pause to let soil settle before the drain valve opened for the pump out because the main motor ran the timer and so the main motor had to keep running all through the cycle. The machine that GE came out with in 1957 was a great improvement over this one. Speaking from decades later, we can see how things improved, but then, what you saw was mostly what was available. There was one Westinghouse with a metal impeller. That combined with the guaranteed 140F water heating which extended the wash to close to an hour chipped away at soil, but the drain pump was small and did not move much more than water.
There were several machines in this generation that used a powerful pump instead of an impeller: KA & of course, Waste King, then less powerful pumps like Youngstown with an indirect spray system, the James and the Frigidaire spin spray tube.
Some of those old impeller machines cleaned about as well as the spray-arm machines of the day------ unless they had a filtration system. I don't think most housewives or housekeepers just scraped the plates in those days. They Rinsed everything as they loaded the machine.
Used many old Westinghouse pull-out machines and they cleaned well.
The Youngstown machine I remember had a Roto-Rack on top. It was pretty amazing how fast that would spin. I think this was about as good at rinsing as most. Don't recall finding all the little food bits on upper rack items.
The impeller machines were pretty noisy. The sounds of the water slamming into the sidewalls.
The little GE Mobile Maids were the loudest dishwashers I Ever heard! When GE came out with spray arm models the water wasn't nearly as loud as the pump. Especially the builders grade machines that went into a few million apartment complexes. Sounded like a circular-saw. No filtration.
I don't know where Frigidaire sourced their impeller machines from, and they had them.
Then they built the "Radiatube" spray machines. I had one in an apartment so I had a chance to experience one. A novel system that didn't do very well.
Then they came out with a spray-arm machine. They would hold a lot of dishes and large pots. The top racks were really deep,too. I had a Custom Imperial. It had the kool little "Whirly-gig" on one spray arm but still lacked a filtration system.
In those days you could really tell the difference if you used a Kitchen Aid.
Thanks for the input, had really wondered as I never had any experience with them. Just from the pictures they didn't look like they held a lot of dishes. Had only seen one back in 1973 or so. Always thought that if it was improperly loaded that it would impede cleaning. I could see how they would be noisier. My mother always rinsed the dishes before loading, we didn't get our first dishwasher until 1974 when I was in high school!! Military bases didn't furnish them in all housing back then.
Gyrafoam, interesting that you mentioned Youngstown having the upper roto-rack, maybe that's where Kenmore got their idea for their 60's-70's machines (but of coarse, Kenmore was always "roto" something or other! Lol!!).
Thanks again,
Barry
