POD Easy Washer (10/27/2025)
daveamkrayoguy
Silver Member
Dec 8, 2010
5,798
Oak Park, MI
It’s a Top-Of-The-Line, so what does each button do?
I don’t see a knob that would regulate the water fill-level, so is this a timer-fill?
And is it made by Gibson? A Gibson-branded as Easy instead of its parent-name?
Wonder why Gibson went as Easy in the beginning of its laundry appliances line, or was it its own company?
Easy was a separate brand/manufacturer from Gibson.
The eight buttons, left to right:
Wash & Rinse (temperature): Hot/Warm, Warm/Cold, Cold/Cold
Wash Speed: Normal, Gentle
Spin Speed: Normal, Gentle
Water Saver: manually depress to begin agitation with less than a full wash fill. Does not affect the rinse fill unless perhaps the user returns to press the button again?
Timer cycles: Regular, Delicate, Soak. Regular has a choice of wash times. Delicate and Soak each appear to have one starting position.
It doesn't appear to be timed-fill, but is a solid-tub machine. There's a reference to "Positive fill system insures a full water level even with low water pressure" so possibly the normal (full) fill is controlled by some overflowing into the outer tub to trigger a pressure switch?
