POD Hotpoint Portable Dishwasher
tomturbomatic
Gold Member
May 21, 2001
21,875
Beltsville, MD
Decades ago, I found a machine like this, although a built in model. It was out on the curb in front of a circa 1956 house on Reno Road in upper NW DC. I got someone to go with me and I put it in the back of my Toyota Celica. That beautiful timer lens was broken. I remembered it from the dishwasher at a friend's house back in Decatur. A light bulb illuminated it as it turned through the cycle. John and Jeff told me to check with Proctor & Hutchinson appliance service in Silver Spring. When I gave them the model number they sold me the last one they had. It's still on the machine.
They were fragile machines. The screw that held the impeller onto the motor would rust and not be removable. It went through a tube in the bottom of the tub so the motor was subject to damage from the moisture and back when early dishwasher detergents did not control suds effectively, suds could go down through that tube and cause the motor to burn out. Lots of old Hotpoint dishwashers sat there dead for years. The Bakelite leading edges of the impeller would lose their sharpness over time and the water spray would have less force.
road trips are exciting
i know. been on a bunch! especially when you bring back a truck load! but even if you only go for one it is a great time! just don't drop it off the back of the truck like i did when i went to new york for my custom imperial 65 rollermatic!
getting back to the hotpoint dishwasher i'm surprised they used a bolt that would rust! and the g..e. impeller machine i'm working on now also has that center tube that the impeller sits over. i was wondering if water would ever get down thru it into the motor area. ofcourse the one i'm fixing up will only be used as a novelty, maybe twice a year.
my impeller is also frayed and chewed up on the ends but i did buy a couple bakelite impellers from larry in parma at modern parts about 15 years ago. i can use it but it is not made for that style motor shaft so i'll have to rig it to fit the end of the motor shaft and not slip. it's workable.
have fun on the road trip too!
